Replacing my clutch, need help
I am replacing my clutch with a performance one because my old one wore out and I have some minor mods, but think I might do more later, so figured might as well get something a little better now. I have heard really bad things about centerforce clutches and was wondering what you guys thought would be good. I have a limited budget of about $250, but I would prefer to spend as little as possible since I am a broke college student. I have found two clutches but I don't know if they would be good or not: http://www.summitracing.com/parts/MCL-75115/,http://www.summitracing.com/parts/SUM-700156/. Any help would be greatly appreciated.
I'v been using a centerforce clutch in my street/track car for years. I beat the crap out of them behnin d a 550+hp motor on a road course pretty often, and they just keep going. Real smooth on the street, too. I have abnsolutly no complaints. It just plain works. I'm afraid to try anything else.
The Centerforce hat is made by Valeo. Centerforce adds the counterweghts. It wouldn't surpise me to see the Valeo stamp on the Summit clutch, too.
Centerforce here as well. I flog the crap out of mine and drive it every day, the last one probably went 150k+ miles.
I've found in pretty much every case of a Centerforce clutch horror story, the clutch was not broken in, and as a result it failed prematurely.
Can you explain what you mean please? Broken in, as in what?
I have also heard that when replacing a clutch you need to replace some other things too like the able and such. Is that true? If so what all needs to be replaced? Thanks for all the input I really appreciate it.
I replace the cable when it needs it. That's an easy part to replace at any time.
For the TO bearing and the cable, I only use Ford parts. Only slightly more expensive than aftermarket, but so much better.
