Anyone know how a gt40p engine has a compression ratio of 9:1
I have looked online and have come to the conclusion that a explorer engine with gt40p heads has a 9:1 compression ratio. I am just not sure why. Explorer engines with the 3 bar heads have a 9:1 compression ratio also. So what is the difference in the shortblock? The heads have a 5cc of difference or so in the combustion chambers. So why would the compression ratio be the same?
Actually it's because the GT40P heads have a 59cc combustion chamber instead of the E7's 63-64cc combustion chamber. On my 306 after having my deck milled .010", adding +3cc flat tops, and gt40p's it yielded me a 10.2:1 CR.
true but reread his post, that does not answer his question, two different chamber heads on the same bottom end would yield different cr's , so to remain at 9:1 on the p head explorer motors the piston would have a slight dish to compensate for the smaller chamber on the head
09-03-2015 07:14 PM
1996, 306, 351, 50, chambers, combustion, compression, differences, engine, gt40p, heads, milled, motor, mustang, ratio
