New Electric Fan/thermostat opinion
Old 06-25-2010, 12:14 PM
StevoX1
StevoX1's Avatar
Default New Electric Fan/thermostat opinion
Alright so i got myself a black magic electric fan that a friend had an extra of from rebuilding his fox, i'm looking into gettin the relay switch for it and the ones i'm lookin at are based on the thermostat settings, with that being said i was just going to replace the thermo as well since i have no idea what temp setting its at.
I live in so cal, gets pretty hot in the summer, which is now, so should i go with the 180 or 195 thermo?
The relay made to work with a 180 deg thermostat and will come on @ 185 and off @170.
The relay made to work with a 195 deg therm. and will com on @200 and off @ 185.
Thanks.
StevoX1 is offline
Old 06-25-2010, 12:51 PM
stanks347
stanks347's Avatar
I am using the 180, it seems to be just fine. SBF's don't like heat.
stanks347 is offline
Old 06-25-2010, 07:00 PM
luckythirteen13
luckythirteen13's Avatar
go with the 180* stat.
and if you dont already have the relay, check out the DC controller. i use it on my truck which is my DD and it works fantastic
luckythirteen13 is offline
Old 06-26-2010, 09:51 AM
KNS1
KNS1's Avatar
Check out ronfrancis.com for some high quality wiring harnesses for electric fans. Buy good quality stuff the cheapo chinese junk will leave you on the side of the road.
Go with the 180 stat
KNS1 is offline
Old 06-27-2010, 01:11 PM
Jfsram
Jfsram's Avatar
Thanks.
Where did you get this information from?
It's all wrong.
Jfsram is offline
Old 06-28-2010, 06:07 PM
KNS1
KNS1's Avatar
^ I think he is using the term relay instead of temp switch. And as i read it he means the switch for a 180 stat will run the fan between those temps and so on for the other.
KNS1 is offline
Old 06-29-2010, 08:50 AM
Jfsram
Jfsram's Avatar
Well then it's still wrong. An electric fan is meant to pull down temperatures above thermostat temperature.
If you try to pull the temperature of a 180 deg thermostat below 180. It will never get there. So the fan will run forever.
The OFF temperature MUST be above your thermostat temperature.
Jfsram is offline
Dokilar
15
10-16-2015 08:13 PM
LiquidDrink
09-29-2015 10:06 AM
mrappe
09-26-2015 10:16 AM
Mr. D
09-17-2015 08:17 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: New Electric Fan/thermostat opinion
