580 crank or at the wheels ? i was refering to rw btw. that str8 surprises me. i was being conservative of course but still. also dont remember all you had done to it though
hell i just wanna see 400.... but i think im there. if not i'll spray more
At the wheels sir....Oh, that is on 110 octane and timing bumped up as well.....14 Pounds of boost, and the tires were slipping on the dyno...I am running Hoosier 275/40/17 DOT...Not the best tires to do a dyno run. Should use a good heavy tread to grip.
The front end of that jeep concept looks like the new taurus.
I am hoping to be in the mid to upper 10's....If I can hook and shift, then we are golden, if not I will let a pro try to see what actual potential the car has. I don't have a cage at this point since the car was just finished...I have a quote for a 6 & 8 point cage which I will need for sure if the car gets into the 10's.....
