Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: How to Flush Radiator
Step by step instructions for do-it-yourself repairs.
proper way to flush 5.0 radiator/cooling system??
hey guys... what is the proper way to flush the coolant system in the 5.0? my car almost overheated in city traffic with the A/C running yesterday and i want to clean it out... from what i can tell, original rad, waterpump and most of the hoses are original too, no leaks, coolant is kinda dirty looking....
do i just drain the plug then run the hose through the rad until it cycles through till the water is clear? then fill it with a 50/50 mix...
The drain plug, cycle water through it is good maintenance. This should probably be done every 5 years or so. The fill should be 50/50 using distilled water.
Look up your cooling system capacity and if it's 14L system then make sure you pour in 7L of coolant. If you drain and fill the radiator with 50/50 mix. It will be diluted because there is alot of water in the engine block and heater after a flush.
If you do indeed have an original radiator. Don't expect too much from a flush. It may be time for a replacement.
go to walmart and buy some of the radiator flush its about 8$ and the flush fittings they are about 4$ there too...you splice the fitting into your radiator hose drain the water put the flush in and fill with water drive for a few day to let it work its magic
then flush the stuff out with your water hose attached to the fittin in your radiator line
and refill with antifreeeze
you dont really need a 50/50 mix in the summer infact it will cool a lot better with less antifreeze and more water
thanks guys. yeah its the oe rad or at least an oe replacement, has the ford stampings on it, and judging by how much of this car is still OE, i wouldnt put it past it to be the only rad this car has ever had... hell the shocks were original when i bought it...
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
