Having some fun with the new H/C/I set up **video**
it starts around 2000rpm, real bad between 2500-3500. found my starter had came loose today, got it tighten up with some locktite, and looking down at the starter while revving between 2500-3500rpm it just shakes so bad. looks blurry its vibrating so bad.
I've checked the motor mounts, trans mounts, and clutch, and nothing is wobbling, or anything. everything seems fine.........
summit racing, $180. ill put the link below.
lol, yea, it was all over the tank, the tail pipes, everything.
do you have to run those for a class or something?
seems to me you need a more serious tire if you need THAT much heat to get it to hook.
I have, took 1.1 off the 1/4mile ET from the stock heads/cam from last year, and that was before the tune. hoping to drop a few more tenths now.
http://www.summitracing.com/parts/PIO-872030/
very nice piece. only bad part is the fact that its refective, so setting the timing is difficult off the marks that are on the balencer. I had to use white out, and even then it was still difficult to see the timing marks.
you know what, today when I was coming home 3-4 times it was trying to die when I was taking off. I would have to push the clutch back in to stop it from dying and use more RPM's, it also died when pulling into the garage the same way.....
maybe its time to adjust them.............. AGAIN.
Thank you sir!
haha, glad to see a 50yr old man still living it up!
ummmmm this covers mostly everything.
Modifications:
Trickflow Twisted Wedge heads,
Trickflow stage 2 cam,
typhoon intake manifold, upper and lower,
(intake is port matched to the heads, and cleaned up)
bbk 70mm throttle body NO EGR, or emissions
Pro-M 75mm MAF,
Stack Racing cold air intake,
Mark VIII electric fan, and DCC controler
underdrive pulleys,
bbk shortie headers,
bbk offroad h pipe,
mac catback,
Complete Emissions system delete,
Complete A/C system delete,
MSD ignition coil, & Anderson Pluge wires
promotion powertrain Cobra T5 transmission
aluminum driveshaft,
4.10 gears
maximum motorsport full length subframe connectors
Strange engineering shocks and struts
275/50/15 micky thompsons on weld drag lites.
Thank you sir!
Sounds damn good!!!!!!!!!!!!! One thing my wife never tells me to do is, Grow up. Because I never did. 50 year old kid here. Only live once and ya can't take it with ya.
First time I've had tires last on the back of mine for more than 6 months. I am starting to get a vibration on the block at 38 to 4k. Going to replace the HB soon and see if that is my problem.
Modifications:
Pro-M 75mm MAF,
underdrive pulleys,
bbk offroad h pipe,
mac catback,
4.10 gears
lol yeah every car is different but hey tires are just a expense when you start going semi fast, but yeah got my 3.55 gear and spool this week for free now just have to get those installed and i have a set of 28x9 slicks waiting to go on
thanks, I love the sound. The powerslides where fun, but the camera doesn't really pick up how sideways I got. I should have changed the angle up. but I know better for next time now, lol
BeatnikFink
10-01-2015 08:00 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mungodrums
Suspension
09-24-2015 10:12 PM
