Cutting Eibach Drag Launch Springs
Hey guys, Just wondering what your stance is on cutting these springs, or cutting springs in general.
I saw a picture of someones stang who cut a coil and a half off his springs, and the stance looked mean as hell.
I've got a set of eibach drag launch springs, but the car sits way too high for my liking.
Some springs are designed to be cut and some aren't. I believe it has to be a static rate spring but not sure if its always OK. Progressive rate springs get messed up if you cut them. The spring rate gets harsh and it is hard to know how much drop each cut will make. You can cut them but probably won't like the ride as much as the look.
ive cut mine, it gets a really low front rake when you do this. i cut exactly one coil off. i shouldnt have though. my 60's suffered because of it. but if its only look you're going for then buy a different spring because a drag launch isnt a lowering spring. its function over style with them.
I understand my 60's would suffer, but I dont really take my car to the track, and I bought it with them on.
I just dropped loads of cash on new drag lites, a manual valve body, a hurst shifter, and to fix the leaks on my c4. I just want a meaner stance for now..
i wouldnt cut them. its screws up how the spring performs. springs rnt that expensive. like $250 ish you will get the look you want and a good ride quality as well. plus you can sell the drag launch springs you have now and make some of that money back.
try h&r super sports. i havent used them yet but those are my next set if i decide to keep my car.. it has blue eibachs in there now which i assume are the drag launch but im not too sure. but they are def worn out in the rear. plus they look like doo doo cuz the front is a lot higher than the rear..
Hmm. Guess if I do it, I'll do it right.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
