transmission and clutch and gears
am having a 347 with eagle forged crank & hbeam rods comp cam .555/.565 xtreme energy cam 1.6 roller rocker arms rhs pro action heads 10to1 compression edelbrock rpm II intake 42lb injectors 70mm throttle body 255lph fuel pump. It has a 5speed in it now what would be a good transmission and clutch to use and what rearend gears should i run. Its going to be use for mostly cruising and track once in awhile. It is going in an 89 lx
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
