cam in stock 5.0
cam in stock 5.0
im thinking about swapping out my stock cam for an aftermarket one, maybe a b303. i want to do this mainly for sound, but i do not want it to negatively effect my cars performance. the car is primarily a street car but will be built for roadracing. so i want to focus mainly on suspension and brakes first, but ive found myself thinking more and more about swapping out the cam for the time being until i can do a full H/C/I.
so ive got a few questions on this before i do anything:
~ is there a better cam choice for what i want besides the b303?
~ will i notice any performance losses by doing this?
~ what other parts will be needed to run the cam safely in the car?
thanks a lot guys....
Most everyone will have this: alphabet cams=you can do better, old stuff. Cam by itself: wait until you have heads intake throttle body aftermarket headers. I piled parts around spare room, garage, and shed for 16 months untill I had a build ready.
right now, i just want the cam for the sound IF its not going to noticeibly effect my performance negatively.
i know i wont benifit from this, but im concerned about loosing power. how would a stage 1 tfs cam work in my car? i also posted on another forum and they sugested comp XE cams, how would one of them be?
If you are doing a cam and have the stock e-7 garbage heads off anyway, just pick up a set of low milage explorer gt40p heads for <$300, get stiffer springs for them and use a comp cams xe270hr with 1.6:1 rockers to clear stock pistons. And you can pull the explorer (gt40) intake from a junkyard for $70. This will really wake the car up for cheap!
If you get the "P" heads, you need different headers. The BBK longtubes work with them fine, you just need two spark plug wires with a 90*bend and heat wrap. Or you could use stock headers with regular gt40 heads. Still a HUGE improvement in HP.
im not a big cam guy... all i can tell you is that that tfs cam is split duration, and a 5.0 favors exhaust. but the stock stuff will support 300-350 hp, i have sprayed too many stock cars to prove that a fact. so if sound is big for you....go long tubes. dont bother cam til heads and intake....it' all gonna come off anyways... why put back on stock ?
e7te heads are a pretty good stock head. like i said.. ive gone 12.50's on them
gt40P are crap... gt40 i like but they like some exhaust porting...p's are good for paper weights or tie em together for a boat anchor
gt40 intake from an explorer has tiny ports... the BA lower really limits you and im not really convinced it's anything over stock. again... the stock intake will support a lot more than most give credit for.
to each his own... i disagree with everything he said.
No offense, but why do you think the P heads are crap? They flow better than the gt40's and have a better designed spark plug location.
