z cam on stock 5.0?
z cam on stock 5.0?
Advertised Duration 290/290, Lift .552/.552
just gunna get some heads. probly gt40 heads off an explorer. will this work?
what all will i need to do to make this work?
thank you in advance for the help guys!
degree wheel, piston stop, proper valve springs/retainers/locks, push rod checker, new pushrods.
you can make it work if you have some kind of valve relief in the piston but you need to double check your clearances and valve events.
IMO find another cam...letter cams are not very desirable
