What to do, what to do?
Hi all,
I've got a bit of a dilemma I'm looking to make my 90 GT go faster but I dont know what to do. I've got a 500 dollar budget right now and the car is stock except for an x-pipe cat back, shift kit and A/C delete. Now when I got the car the guy I bought it from gave me a 31 spline 3.73 traction lock rear should I invest in getting the stuff I need to put that in the car or take another route?
Did you get the pinion gear with the 3.73s? Are the clutches and spyder gears installed in the carrier? If you have all that then you can buy 4 lug 31 spline axles and use that carrier and gears(needs to be installed by a professional). If not then you can have gears installed using your current carrier but you'll probably need a rebuild as well(needs to be installed by a professional). Both routes are within in or just over your budget. Most likely over..
Hi all,
Ok sorry if it was unclear before currently in the car:
x-pipe/Cat-back
Shift kit
A/C delete Bracket
Parts that came with it but I havent put in yet:
B&M Megashifter
Complete 31 spline 3.73 rear
SN95 Spindles and front brakes
x-pipe/Cat-back
Shift kit
A/C delete Bracket
B&M Megashifter
