Speedo Gear??
Speedo Gear??
Obviously after swapping in the 3.73's my speedo is off. Looking at latemodel's chart they don't have a gear for a 93 with 3.73's. Theirs stop at 3.55's.
http://www.latemodelrestoration.com/...lication-Guide
Now they do sell a kit that has the speedo gear and trans' drive gear that would make it correct but what do you guys use for the speedo gear itself?
wheel size also effects this reading, since you have 17s... try calling Late model and talk to one of their tech guys. someone once told me that you can talk to a ford tech... but they prolly dont even know anymore
As long as the tire height is the same as stock the wheel size itself won't affect it. There would be very minimal difference from that. I have no issue doing the work to install the gears and make things work properly. I have already done the calculations for the rpm and speed but having a speedo that works correctly is always nice
All I need to know is wat gears you have, what type and what year your trans is
Post that and ill give you the right info
also, the wheel size has NOTHING to do with speedo accuracy... its all about the OVERALL DIAMETER of the rear tires.
Adder you quoted the info.
FRPP 3.73's
93 T5
Thank ya buddy!
Right now the speedo is just about 10mph fast. As far as I know the drive gear inside hasn't been touched. Right now the black 20 tooth is on the cable for the 3.08's that were in the car.
http://www.latemodelrestoration.com/...ear-Kit-Manual
FRPP 3.73's
93 T5
Thank ya buddy!
FRPP 3.73's
93 T5
Thank ya buddy!
FRPP 3.73's
93 T5
Thank ya buddy!
AAANYway..... Assuming your T5 is a 93 model, your will have a 8T drive gear on the output shaft, The maximum gear you can correct for without ripping the trans apart (which isnt hard) is 3.55's. That would require you to use the Jeep 23T white speedo gear.
Now if you want your speedo to be correct, you will need to remove the tailshaft housing and swap the gear to either a 6t or 7t gear.
a 6T(black) drive gear will require a 18T(yellow) speed sensor gear
a 7T(yellow) drive gear will require a 21T(red) speed sensor gear
