Need Horsepower
I have a 1994 Gt 5.0 and it is stock. The only thing I have done to it is a cold air intake and new underdrive pulleys. Does anyone have any ideas what kind of stuff I can do to it or things I can add to it to add more horsepawer without spending a bunch of money? Some cheap fixes
A tune up would probably help you out quite a bit, but not so much if it has been done recently.
"Cheap" fixes would be bumping up the timing and removing weight since our model is made to represent a fat chick... =D Other things you may consider (depending on your ultimate goal with the car and budget) would be gears (3.73's), full exhaust (you can buy in stages), and then it starts getting progressively more expensive.....
Again, this all depends on your goal for your car..... make sure you set a goal before just dump money into your ride.
fo sho... go here for starters
http://www.holley.com/division/NOS.asp#16
then get 4.10's and a set of et streets on some spare wheels. if your happy going 12's... leave it alone. if you still want faster.... save for heads
01-06-2016 07:03 PM
09-18-2015 12:25 PM
Other Professional Racing
09-10-2015 11:41 AM
