No fuel - Electrical issue?
I've replaced the relay, pump, and ignition switch on the steering wheel. The pump went out on me within a month and am wondering if I got a crappy dud or if there's a possible underlying reason. The pump isn't priming when the key is turned on but once I pull it out, all I have to do is put 12v to the pump and it should prime if it's working, correct? The relay is also clicking. If the pump is fine then I'm stumped on anything else it could be.
Or....you could use a test light to see if you have power going to the pump when the engine is cranked. The ecu will only feed power there for 2 seconds unless it recieves a tach reference signal. So, you will need 2 people
And with all your mods, im going to assume you bought the car like that or had someone do the work?
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
