Part names
Part names
I have finally fixed the car to a drivable condition and today the first snow fell out, so it's awesome. But there are still few things that I have to fix, and I don't know what to order. Maybe someone can tell me the English names for them.
So far the following parts are in poor condition:
Front left brake disc metallic cover (from the inside) is missing- Backing plate
Rear left axle "seal", the oil is leaking through the left axle outer end. axle seal
Front cross of the cardan
Rear brake metallic tubes are rusty
Handbrake lines - Emergency/parking brake cables
Bushings for rear end (rubber stuff) control arm bushings??
Tie rod end left, there is a metallic pulsating sound when I brake as the front rotors are warped. outer tie rod
Also, another 99-04, 4.6 Mustang owner asked me what is the name of the rear secondary strut/shock absorber. The part that's absorbs side-way shocks or something. quad shock
P.S.: What is the name of that cardan safeguard that doesn't let the car to be thrown over if it comes loose? sway bar???
Thank you! List already helps!
Nope, I mean the part that's a requirement for serious drag race use and is an aftermarket thing. Cardan (the large axle that transfers power from front to rear) it's connected with cross type connectors, and if one of them breaks loose, the part falls down while still having a rotational inertia and this can cause a lot of damage. There are some sort of rings that can be fitted to the underside of the car that won't let it fall down in these cases.
Yep, drive-shaft, U joints, and drive-shaft loops! Thank you a lot!
I wish everyone used the same terms, the mechanics here usually use Latvian and Russian terms which are completely useless when you actually have to order the parts.
So the last question is, the metallic brake tubing, can you get them as a replacement and do they have a name, or should I just fabricate it via universal brake tubing and end nuts?
P.S. Are all bolts on this car metric or are there non-metric bolts too, especially concerning break line end nuts?
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
