Got the tranny :))))))
Ross-Lock™ PRO Tree Brake
Pro Mod Ringless Input Shaft Turbo 400 Spline
Over sized Billet Steel Clutch Hub
10 Clutch Pro Mod Drum
Max Surface HD band
Front Pump Bearing Kit
Light Weight Billet Servo Cover
Billet Aluminum Dual Ring Servo
Modified Front Pump Converter Charge System
Pump Gear Lube System
1.80 Straight Cut 12 DP Tooth Gear set
SFI 30.1 SFI 4.1 Reid
Rollerized Case and Rear Support
Deep Cast Alum. 2 qt Extra Capacity Transmission Pan
Max Surface HD band
