aluminum head help
No Trickflow intake. had a 93 cobra upper and lower with a 1" spacer , a bbk 70mm throttle body and 24lb injectors. (all of which are for sale.... lol)
when i got the car i was told it was a dss 347 with trickflow heads that had 2.02 valves in them. I am in the process of slowly pulling it all apart as it is a little low on oil pressure so i am going to install new oil pump and cam,crank,and rod bearings while im at it as i am figuring out what is fact and what is bull that the previous owner told me. its looking promising if these are trickflow heads.....
i guess now i have to figure out how to tell if it is a dss block
thanks again everyone (expecially you AdderMk2 for finding those pics of the tw heads)
DSS blocks are stock blocks... they are nothing special.
When you pull the heads off, lay a straight edge across the top of one of the cylinders, and rotate the crank until one of the pistons reaches BDC. Measure how deep in the hole it is. Should be 3.4"
you cant see this as in you dont think it is a dss build. or you cant see the area that they inscribe by my pictures? if it is the wrong pic or angle tell me what you need a pic of and ill try and get it
OK. THANKS FOR ALL OF THE HELP GUYS!!!!!!
I just got off of the phone with trickflow and the heads are a set tristed wedge 170 head 66cc with 2.02 1.60 valves.
can anyone tell me how much power the heads are capaple of making? the small runners have me wondering if i need to go with a bigger head
