ffrp ac delete (p/s relocation kit) with supercharger
can i use this
http://www.jegs.com/i/Ford+Racing/39...1-A50/10002/-1
with a vortech v-3 si-trim supercharger kit?
ok great! Another question mjr, know how the alternator/smog is relocated?
I don't have a smog, using the ac (ps relocation) delete kit, do i need a smog pulley? Or can i still route the belt in a good way.
And eventually i want a 3g alternator again which requires bracket modification on the stock setup, but will i have to modify the supercharger bracket to hold it too?
the v-1 kit I'll have or that I just took off of the car I'm doing relocates the alt down at the bottom where smog was, and it had a smog eliminator pulley figured into the supercharger bracket , so I assume , you will either need the smog pump for it's pulley or the smog eliminator pulley.
jwog666
12-27-2021 08:09 PM
