Aluminum flywheel
Aluminum flywheel
I recently did an aod to t-5 swap. Everything worked fine until I stopped at a gas station. When I started the car, there was a pop in the motor. It drove, but was making an intermittent clicking. I took it back home, tore it down, and found a broken flywheel bolt head trapped in the recess between the clutch plate and the flywheel. The flyweel was scrached and gouged pretty good in this location. Then it refused to come off of the engine - The remains of the broken bolt would not let go,was unaffected by heat, had three easyouts broken off in it, wouldnt budge. The flywheel, beat up from the bolt tumbling and jamming against it, was finally sacrificed to get it off. I used brand new ARP bolts for the flywheel as well as pressure plate.
Ok Im stupid I bought another aluminum flywheel (fidanza knock off). Im thinking I should have stuck with steel, but I am going to forge forward once I get new flywheel bolts. I was hoping people had some tips for installing an aluminum flywheel?
I find it strange that one flywheel arp bolt would break off, did you use a torque wrench or an impact wrench, because it sounds to me the bolt broke when you tightened it. I would send the bill and bolts back to arp for the new flywheel.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
junior04
09-28-2015 10:53 AM
