master cylinder/brake question???
Old 07-03-2011, 06:41 PM
kweb288
kweb288's Avatar
Default master cylinder/brake question???
Ok so on my build, i have stock styled front rotors, with 4 piston rear disk brakes and a stock replacement master cylender on a manual brake kit...
After bleeding the brake system i am not getting ANY brake feeling, do i need to upgrade the master cylinder with such a combination??? thanks for the help
kweb288 is offline
Old 07-03-2011, 10:51 PM
AdderMk2
Banned
AdderMk2's Avatar
should have done a 5 lug swap and new edge front brakes.
yes, you need a new master, and you also need a new proportioning valve
AdderMk2 is offline
Old 07-03-2011, 10:59 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I would just look into swapping over to the hydroboost system that goes with the motor and upgrade to SN fronts.
projectresto83 is offline
Old 07-04-2011, 06:51 AM
kweb288
kweb288's Avatar
nope, not doing the hydro boost system, ive seen how complicated it can be especially with the "no room issue"
already had most of the 4 lug stuff including wheels so why switch over to 5 just to re buy everything?
Adder, is there a website to figure out what master cylinder i need? or any info you could give me?
thanks guys
kweb288 is offline
Old 07-04-2011, 07:27 AM
AdderMk2
Banned
AdderMk2's Avatar
93 cobra would be a good place to start
AdderMk2 is offline
Old 07-04-2011, 03:24 PM
5.0kid
5.0kid's Avatar
skrc sells a manual mc with the correct proportioning might look there
5.0kid is offline
Old 07-04-2011, 05:24 PM
kweb288
kweb288's Avatar
ok thanks alex!
kweb288 is offline
lincolnshibuya
07-05-2020 03:05 AM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: master cylinder/brake question???
