Smog pump delete kit screws?
Just like it says, I don't have the screws to install the delete kit and looks like most don't come with them. Can anyone tell me what size and type of screws used to attach your smog/delete kit?
I have that now but it is getting all chewed up. Is it possible my belt isn't short enough. The problem I am having is the belt almost touches on the idler pulley and it seems to be getting chewed up.
Any ideas?
Any ideas?
I believe he's talking about an idler, its considered a "delete" because it takes place of the pump without searching for a different size belt. I believe you use the bolts that originally hold the smog pump in place
Take a piece of string and route it around your pulleys like you would your serpentine belt without the pump. Match up the start and stop points and measure how long the string is. This will give you an idea of the size belt you need, it may be off only slightly.
