Should I read the stickey's???
Hello all-
I have a 91 vert that's been sitting for 2 yrs. Just a little background, I live in southern California so im sure you all know smog here sucks @ss! But there's always around that with $$$!
Here are my spec:
Trick flow head
Holley system max intake
Accufab throttle body
Mild cam
Maximum motorsports roll bar
Mm coil overs with spring
Mm sub frame
Ford racing injectors
Ford racing shorty headers
Cat back dynomax
Fluidyne 2-row alum radiator
3.73 gears
Cowl hood
The list just goes on and on. I've spent a lot of money into this car but it just sits outside with it's cover on. It does have sentimental value to it, but I'm just not sure if I should let it go. I do start her from time to time, still sounds bitchin! What would you do if you had a clean machine like this with only 89k miles on it? Just trying to get opinions....
Here are my spec:
Trick flow head
Mild cam
Mm sub frame
Cat back dynomax
3.73 gears
Cowl hood
Matt's 95 Stang
10-05-2015 07:16 AM
09-27-2015 03:16 PM
