What distributor to use
Old 11-02-2011, 12:52 AM
neo8222
neo8222's Avatar
Default What distributor to use
I've got a project I'm working on and I'm new to distributors. I've got a MSD 6200 ignition coming to me in the mail to fire off a 351W I'm building but I need advise on which distributor type to use. Seeign as the 351 is pretty close to a 302 I figure someone in the forum could help me out.
I'm still up in the air for what compression ratio to run but I know I'm going to use a 600 cfm carb, i got a pair of gt40p heads on the way, shorty headers, and that msd 6200.
Open to all suggestions on any subject of the build.
Would a good option be to get a used motorcraft points unit and convert it to a digital igniter like this? http://www.hot-spark.com/1-3FOR8U1.htm
neo8222 is offline
Old 11-02-2011, 01:30 AM
tinman
tinman's Avatar
If you already have the engine built, the compression is what it is.
I would go with an MSD distributor, good product and compatable with all other MSD stuff........
tinman is offline
Old 11-02-2011, 01:17 PM
5.0kid
5.0kid's Avatar
crank trigger setup and a msd billet would be the way id go
5.0kid is offline
Old 11-04-2011, 09:00 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I'm not hating on it but I'm gonna say it before someone else on here does.....
302 parts make 302 power....talking about the P heads....
Now if I am working with the same budget when I go to build a 351w myself sometime I might end up using my ported GT40's just because I am cheap.
And since you are using those heads and didn't mention anything about a power adder I would stick with the stock dizzy and the 6200 running that...
projectresto83 is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
StalkerGT
09-25-2015 02:41 PM
dalehunter
09-25-2015 10:51 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: What distributor to use
