94-95 speedo gear...
Old 11-10-2011, 04:54 AM
DeathRattle
DeathRattle's Avatar
Originally Posted by AdderMk2
running a specific gear has nothing to do with tuning the shift points. The AOD does not depend on speed to control shifting, as it is not a computer controlled trans. the AOD guys can only run the 23 tooth gear to correct for 3.55, and its the best they can do for 3.73+
The guys that run a 21 tooth gear, do some because the 23 tooth gear usually chews up in about 10k or less miles. But in the end, the speedometer is still wrong. Their reasons for running a specific gear outside of the parameters of correcting the speedo are irrelevant. The ONLY other case of using a different speedo gear that what is suggested on the chart, is if your tires are a different size. Thats it.
The AODE is the only trans that can truely benefit from the speed-cal. Regardless of what anyone tells you about why you should run X gear, you NEED a speed-cal to correct YOUR speedo for any gear over 3.55.
Running the wrong setup won't HELP you for any reason.
Ok cool, thanks for the info...
DeathRattle is offline
Old 11-12-2011, 02:56 PM
nitrous_bob
nitrous_bob's Avatar
yeah, ford only made a 21t for the aod (purple one)
the 23t (white one) is used for aod and t5, but is actually the wrong pitch for both...since its a jeep gear.
so other than trying to keep a gear in it....and not chewing it up fast....a 21t is the way to go. and FYI, the 21t is for 3.27's, 23t would correct for 3.55's only
probably 5% error for every gearset you bump over what your corrected for
nitrous_bob is offline
67LimeCoupe
11-25-2015 08:55 PM
Mr. D
Tuner Central
08-27-2015 05:01 AM
Mr. D
Wheels & Tires
15
08-22-2015 02:58 PM
Gregz
08-11-2015 03:42 AM
customper4mance
01-13-2004 01:32 AM
Quick Reply: 94-95 speedo gear...
