90 347 build/ sound good?
Old 01-28-2012, 04:40 PM
mike0593
mike0593's Avatar
Default 90 347 build/ sound good?
this car is a car i have my eye on i just wanna know if it sounds good, are the any problems i would need to fix in the near future such as the tranny. and also some one told me a couple of the parts dont seem right so just let me know. also how much power do you think its pushin?
1990 Ford Mustang GT 182,000 miles on carBrand New 347 Stroker Engine, zero miles, never on the road, with V-1 Supercharger 70mm throttle body. Comp Cam, Roller rocker arms, Windsor Senior aluminum heads, 202/160 valves, after market fuel rails, mass air w/ 50 lb. injector to match, braided fuel lines from engine to fuel tank, two fuel pumps, 255 in tank, Shorties Hedman headers, X Pipe w/ high flow cats, Flowmaster mufflers, Welds Rodlite rims, MSD ignition and boost timing master, stock transmission, stock rear gears and axles, Centerforce dual friction clutch, 28 oz. flywheel balance to engine, aluminum radiator, short throw shifter, Edelbrock Performer II intake manifold, QA1 tubular k-member, subframe connectors, Lakewood drag shocks 90-10 front, 50-50 rear, drive shaft loop, upper and lower control arms, torque box reinforcement kit, caster camber plates, front and rear lower springs, stock brakes, original interior, new carpet, original paint,
mike0593 is offline
Old 01-29-2012, 01:17 AM
tinman
tinman's Avatar
Need pictures.......
tinman is offline
djbigskrilla
09-20-2022 01:04 AM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
Stilz
08-19-2015 06:17 AM
Quick Reply: 90 347 build/ sound good?
