question about gt-40 heads
Old 01-12-2012, 02:08 PM
StalkerGT
StalkerGT's Avatar
Default question about gt-40 heads
i bought my 90 GT not too long ago and the guy i bought the car from didnt know too much about it because he got it from someone that just needed money quick...he wasnt really a mustang guy, just buys and sells cars on the side. So long story short...he was told it had gt-40 heads in it. How can i tell if they really are? Is there a number or anything on them? If they are not i want to put a pair in. Thanks!!!
StalkerGT is offline
Old 01-13-2012, 04:00 PM
my94pony
my94pony's Avatar
gt 40 heads have three bars in the front
my94pony is offline
Old 01-18-2012, 12:05 AM
NateB26
NateB26's Avatar
NateB26 is offline
Old 01-18-2012, 01:41 AM
bluebeastsrt
bluebeastsrt's Avatar
Thats it. Really need a sticky in the 5.0 section about gt40 heads. Question gets asked alot.
bluebeastsrt is offline
Old 01-23-2012, 05:43 PM
nitrous_bob
nitrous_bob's Avatar
gt40 "P" have 4 bars
so hopefully you have 3 bars...cuz i hate P heads
nitrous_bob is offline
Old 01-27-2012, 08:45 AM
The02GT
The02GT's Avatar
Why do you dislike the P heads over the non P heads??
The02GT is offline
Old 01-27-2012, 10:51 AM
StalkerGT
StalkerGT's Avatar
turns out i dont have gt-40's.....think im gonna pick some up soon. Whats a good cam to run with them that will clear the stock pistons?
Old 01-27-2012, 03:56 PM
AdirondackFox08
AdirondackFox08's Avatar
Stock cam with 1.7 rocker arms.
AdirondackFox08 is offline
Old 01-27-2012, 10:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
go over on the corral, there is a entire "sticky" devoted to such
mjr46 is offline
Old 01-28-2012, 06:36 AM
9redfox3
9redfox3's Avatar
Here you go, this thread is designed to inform the the average mustang guru of the wonderful similarities and diffences between the GT-40 and 2 types of explorer intakes as well as the heads that came on them. I will continue to add information as I feel it is needed, or pictures to help. I will refer to the intakes as explorer 1 and explorer 2 from here on out. EXP 1 is the early 95-early 97 intake and the EXP 2 is the 97 and later.
All Explorer motors from build dates late 95 (last three months possibly four), all of 96, and the first two months of 97 come equiped with Cast iron GT-40 heads. They are the same that were on the 93-95 cobra and the 93-95 lightnings. They have 3 verticle bars on the front face of the head. These are not the "P" heads. The P heads were used from march on in 97 up to 00 or 01, whenever they quit installing 5 liters in the explorers and mountainers. The "P" heads will have 4 verticle casting bars on the front face of the heads. (front and rear corners, where the accessory bolt holes are).
Now for the intakes....
Ford had such success with the GT-40 on the mustangs, that they found a way to build a cheaper (for them) copy of the tubular. and the casting of the "Explorer" or Mountaineer" intake was born
the three uppers from left to right GT-40, 96 explorer, 97^ explorer. Notice the similarities on the inlet tube, and the actual shape. The explorer is just an uglyier looking casting of the tubular GT-40
the three lowers from left to right are 97^, Real GT-40, and 96 explorer. Notice the intake on the left with no EGT hole on the upper flange mounting area. Also notice the #5 intake runner with no casting for the ACT hole
EXP 1 had the Same production dates....late 95, all 96, and the first two months of 97 (JAN and FEB) use the intake that is setup to run internal EGR. (NOTE= all explorers had EXTERNAL EGR, but the first go round had the provisions for internal, as they were "leftovers" from the cobra line. There will be a sticker on the intake somewhere around the throttle body inlet that will have the part number, build date and location. Every intake i have had has still had this sticker on it. EXP 2 will be from 3/97 and later.
Here is a pic of the build sticker that was on this early 97 (EXP 1)
You are going to want this intake (exp 1)if you have to pass any kind of emissions testing. This intake also has a boss in the #5 intake runner for the ACT sensor (air charge temp sensor). It will need drilled and tapped to a 3/8 NPT (national pipe thread). Also at the back of the intake, there is a boss that will need drilled for the coolant supply to the EGR space on the throttle body.
Now, the later 97 and on intake does not have the provisions for the internal EGR. Also, there is no boss int the #5 intake runner for the ACT. I have drilled and tapped these before, but the intake runner itself is very thin and there are not too many threads to hold the sensor in. You can either drill and tap the intake runner for the ACT, or relocate it to the air inlet piping for better temp readings. Also, in the rear passenger side where it would need to be drilled for the EGR spacer coolant line, there isn't as much material there.
EXP 2 #5 runner
The early intake 95-96 also has a thicker flange area on the upper ( around the bolt holes that bolt it to the lower). they are about twice as thick as the later intakes. the later intakes (upper) crack quite easily (both ears of the upper on mine have been broke and rewelded. Does not affect performance, but isn't the prettiest. EXP 1 on the left and the later EXP 2 on the right
The later intakes 97^ are easier to find on ebay and in the salvage yards, but are not the better intake. If you are buying one on Ebay, the earlier one will bring more money. Also remember that the later intake will not work with the EGR system and probably won't pass an echeck without it. (I honestly don't know if it will pass or not, as I do not have emissions testing where I live)
Now to sum it all up, the early lower intake is the exact same part number as the lower from the GT-40 aftermarket intake. The upper is a casting of the tubular aftermarket. Where I live, They don't ususally sell the intake and heads seperately unless the motor is damaged, and at the point, you may not want the heads. Some yards will sell you the intake and heads. If they won't, check prices on the entire motor for a 1996 Explorer. Any reputable yard will ask the date. tell them 12/95 or 1/96. Keep it early. There have been some cases where ford mis matched parts like P heads with the EGR intake. I know I've priced a couple around here with 120K miles for about 400-500. At that price you get the intake, heads (GT-40's), and the throttle body. Then you can either sell the shortblock to recoupe some dollars or keep it for a spare. casting numbers for the GT-40 and EXP 1 lower are "RF-F87E-9K461-BA. The EXP 2 casting number is
RF-F87E-9K461-BB. gotta watch as they are almost the same, but only the last two letters changing.
9redfox3 is offline
Quick Reply: question about gt-40 heads
