What gears in my 9 inch?
Old 02-04-2012, 03:24 PM
torchred5.0
torchred5.0's Avatar
Default What gears in my 9 inch?
Hey I just picked up a 9 inch in great shape for $100 complete with axles...anyway the ring gear has the numbers "4210" on it, any idea what gear ratio I have?
Also I saw no c clips, so how do you release the axle to remove it from the tube? Do you have to pull seal to do it? I wouldn't think a seal is holding an axle in!
Thanks guys
torchred5.0 is offline
Old 02-04-2012, 08:48 PM
AdderMk2
Banned
AdderMk2's Avatar
if you can look at the gears without removing the axles, you don't have a 9"
post pictures, count the teeth on the ring gear and the pinion gear.
AdderMk2 is offline
Old 02-04-2012, 09:47 PM
torchred5.0
Just the number on the ring gear...that is another chunk I have in addition to the one in the axle right now...
Old 02-04-2012, 10:07 PM
AdderMk2
Banned
AdderMk2's Avatar
you apparently didn't even both reading my post... you fail.
AdderMk2 is offline
Old 02-04-2012, 11:51 PM
tinman
tinman's Avatar
9" Fords use a retainer thing on the end of the housing.
There will 4 bolts holding it on.
Undo those and the axle will come out.
Then you can remove the center section (pig).
Chances are that it either 3.00 or 3.50 ratio.
tinman is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: What gears in my 9 inch?
