fuel pump not kicking on
Old 02-04-2012, 08:13 PM
marlyman
marlyman's Avatar
Default fuel pump not kicking on
so this just startd happenin the other day with my 88 - i put key in on position an everthing turns on instead of fuel pump..motor turns if i try to start it but fuel pumps not kicking on..i have electric fans an i wired them to my coil so the fans also are supposed to come on while key is in on position but they dont so im not getting power to my coil either..
when problem first started if i left key in on position for like a min or two the fans an fuel pump would kick on on their own..now nothing even after five mins in on position..thought bad connection to starter solenoid or ground somewheres but dunno fuseablelinks seem ok any ideas? like a relay sumewhere or something??
marlyman is offline
Old 02-04-2012, 09:33 PM
marlyman
marlyman's Avatar
anyone know where eec power relays r located ? an i think i heard like a fizzle under pasengerside of dash last time it almost worked think some relay burnt out..guess ima research more but ill keep checkng on here for replys ..
marlyman is offline
Old 02-05-2012, 09:55 AM
nitrous_bob
nitrous_bob's Avatar
have you checked your inertia switch in the trunk ?
there is another relay under the seat too
nitrous_bob is offline
Old 02-05-2012, 01:43 PM
marlyman
marlyman's Avatar
i shoulda put a different title cuz its not just fuel bah cranks ok no start tho im bout to follow instructions from other threads uhg
marlyman is offline
Old 02-05-2012, 07:19 PM
Bubba 95SN
Bubba 95SN's Avatar
veryuseful.com
Bubba 95SN is offline
Old 02-06-2012, 09:06 AM
Tony71502
Tony71502's Avatar
May I ask why you have your fans coming on with ignition switch instead of a relay. Should only come on when needed.
Tony71502 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
Sixx
10-05-2015 07:36 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: fuel pump not kicking on
