Radiator HP rating?
Radiator HP rating?
Anyone know about what hp a stock 93 Gt radiator /water pump will cool up 2? I am planning on switching both down the line if I go super crazy on this car,but for now was just curious.
I understand hp has nothing to do with the radiator.So I probably should have worded this more logically. So A h/c/i swap say... going w/ trick flow top end kit would require me to change the radiator to one w/ a higher cooling rating,even if I use a taurus electric fan or mark 8 fan?
my aftermarket fluidyne radiator and flex fan could not keep up with my motor when it was N/A yet even worse when i put a blower on it. Had to go to an electric fan to keep up. only had issues when i was in traffic at under 10 mph or at lights, once i was up and moving i was fine the flex fan couldnt pull enough air at those low rpms
with a proper electric fan you can build a pretty stout motor and be fine. (like adder said)
with the stock mechanical fan you will run into issues quickly.
I have a "stock replacement" radiator that was on the car when I bought it. It is slightly bigger then stock, and the only time I have problems is when I had the stock cat's on for emissions it would run a tad hot. with free flowing exhaust, and not sitting in traffic I don't even see 170 most the time with a 180 thermostat.
stangin1996gt
09-21-2015 11:01 AM
