302 boss build pics
Old 01-16-2012, 03:27 PM
gideon
gideon's Avatar
Default 302 boss build pics
http://s1144.photobucket.com/albums/o493/gideon302/
just got the motor built a few weeks ago. all forged internals, 302 boss block, dss racing pistons, eagle h beam rods, dss 7qt oil pan, f cam, just got to get heads now...
gideon is offline
Old 01-16-2012, 05:56 PM
Bubba 95SN
Bubba 95SN's Avatar
All that money and a f cam? You can get a better bumpstick.
Bubba 95SN is offline
Old 01-16-2012, 07:07 PM
bluebeastsrt
bluebeastsrt's Avatar
Looks good. what power adder are you going with?
bluebeastsrt is offline
Old 01-16-2012, 09:02 PM
gideon
gideon's Avatar
Gonna put a Turbo on it..
gideon is offline
Old 01-16-2012, 09:15 PM
gideon
gideon's Avatar
The hellion heat kit.
gideon is offline
Old 01-16-2012, 10:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
f-cam?? wtf...girdle on a 4 bolt main block?? now that was a huge waste, not needed at all
mjr46 is offline
Old 01-17-2012, 12:30 AM
tinman
tinman's Avatar
^^^^^^^^^^^^^ I agree^^^^^^^^^^^^^^^^^^^^^^^^^
tinman is offline
Old 01-17-2012, 08:34 AM
uedlose
uedlose's Avatar
F-cam works great for turbos is it the best NO but you can make 1000 HP with the F-cam and a turbo seen it done so why spend the extra $$$ for a custom if not needed unless he is having issues
uedlose is offline
Old 01-17-2012, 12:46 PM
Bubba 95SN
Bubba 95SN's Avatar
Ed Curtis is only $325 for custom grind......
Old 01-17-2012, 04:21 PM
gideon
gideon's Avatar
F cam will work fine. my buddy has the same setup and made 500hp to the wheels with #42lb injectors and 7lbs boost before the fuel ran out. i might run 60lb injectors with 7lbs pounds and see what happens...
gideon is offline
Quick Reply: 302 boss build pics
