Foxbody rear firewall
Decided to move my battery to the trunk today in a continued effort to clean up my engine bay.
Then I read the NHRA rules for batteries in the trunk. Hmmmmmm, now I need a rear firewall, I've seen them for newer foxes and complete rear seat deletes, but I'd really like to keep my back seat. Any suggestions. |
All you should need is a battery box. There are a few members on here that are NHRA compliant and do not have a complete firewall for the rear. I believe that is only needed when a fuel cell is inside the car.
All you neeed to do is to get a 'accepted' batery box for the battery,
Taylor, Moroso are just a couple I can think of that are 'approved'. You'll also need a master switch for a correct installation. DO NOT cheap out on this part. Flaming River makes a good one as does Moroso. I made my own battery box out of .120 aluminum as well as the box that my fuel cell is in. It has passed tech many times at NHRA events. |
I knew about the master switch - but I also have my Nitrous bottle back there and I dont have a blowdown tube - hence the firewall
blown down tube or fire wall.....which is easier/cheaper to install???
Is a plastic tube that vents poisonous gas from the battery cheaper than a firewall? I think not.
The vent tube is to prevent gas from building up in the passenger cabin if the car is left in a garage or some storage spot with the windows up for a long time. Unless you completely seal the firewall with welds or sealant... gas will still permeate into the passenger cabin. At least I think so. |
Blow down tubes are for nitrous.... Nothing to do with the battery.
wolf racecraft sells one
http://www.wolferacecraft.com/detail.aspx?ID=295 |
Originally Posted by 5.0kid
(Post 7889813)
http://www.wolferacecraft.com/detail.aspx?ID=295 Thanks man - just what Im looking for BTW - I ended up @ 120mph on your old springs/ arms. Got taken out a few days ago in favor of coil overs. BUT - its now being moved to a 347 based hatch. Def. a good buy. |
Okay, you do just need a battery box. I have one like this in my hatchback without a firewall. It's been teched and passed, so no problems.
http://www.uprproducts.com/mustang-a...y-box-kit.html One thing I want to mention though, is that I think (don't quote me on this, you should verify for yourself) that if you have a sealed battery like an Optima (that's what I'm running) you don't even need a sealed and vented battery box. Had I known that before I bought my battery box, I would've used this one: http://www.uprproducts.com/universal...ray-satin.html For whatever reason, it seems like I'm in my battery box quite a bit... I wouldn't have to deal with the wing nuts on the battery box if I had an open battery tray like this one. I guess it's just user preference, but there's my opinion on the topic. |
