What type gas put 1991 Mustang LX 5.0?
Old 05-09-2012, 10:56 AM
The_Dude
The_Dude's Avatar
Originally Posted by mustangGT86_05
Consider this, the ho 5.0 is a high compression engine, so that alone tells me put high grade in mine.
Stock is 9:1. That really isn't very high.
The_Dude is offline
Old 05-09-2012, 11:33 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
all right guys, lets put an end to all the misinfo.......if it is a stock 5.0 and timing is set to factory spec still, it was designed to run on 87!! nuff said
mjr46 is offline
Old 05-10-2012, 09:51 PM
oldfordisbetter
oldfordisbetter's Avatar
so should i be getting higher grade fuel since i got a built motor? ive been just doing 89 fuel... its 89 here not 87.... should i go higher? will it run better?
oldfordisbetter is offline
Old 05-10-2012, 10:01 PM
majohns
majohns's Avatar
how is the motor built? what has been done to it? if its a mild build, then yes low grade is fine. if its a borderline race engine then i would suggest higher grade maybe even a mixture of 111, 114, or 118. if its a full race engine i would would say race fuel or carb it and jet it for alcohol. that answer your question?
majohns is offline
Old 05-11-2012, 01:01 AM
Five0hFox
Five0hFox's Avatar
I'm confused, since your sig says you do "high performance tuning", shouldn't you know what octane to use in a car?
Five0hFox is offline
Old 05-11-2012, 05:52 AM
oldfordisbetter
see my sig....
Old 05-11-2012, 05:03 PM
majohns
majohns's Avatar
basically its a carbed 306 with H/C/I. i would say it would be ok to run a low grade gas. prally no real advantage to running higher grade. like i said you want want it to run better mix you some C16 with it!
majohns is offline
Old 05-11-2012, 11:50 PM
primetime5.0
primetime5.0's Avatar
I ran my 348 on 87 octane with 34 degrees of timing.. I do live at a high elevation though
primetime5.0 is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
05slpGT
08-12-2015 02:32 PM
daytooday
08-11-2015 09:22 AM
dangthatsfast
08-06-2015 09:46 PM
Quick Reply: What type gas put 1991 Mustang LX 5.0?
