Brake and Rotor suggestions
I HAVE A 91 LX WITH THE FOLLOWING,
HOLLEY ALUMINUM HEADS, CAM, ROLLER ROCKERS, EDERBROCK INTAKE, EDERBROCK/BBK THROTTLE BODY/SPACER, MSD 6AL, MSD COIL/CAP, ALUMINUM RADIATOR WITH ALUMINUM SHROUD W/ DUAL FANS, BBK HEADERS, H-PIPE, FLOWMASTER MUFFLERS W/ DOWN TUBES, WELD WHEELS, MICKEY THOMPSON TIRES, LINE LOCK, CHASSIS ENGINEERING REAR SUSPENSION ARMS, FRAME CONNECTERS, SUPER T-5 5SPD TRANSMISSION, HEAVY DUTY CLUTCH, PRO 5.0 SHIFTER, AND ALUMINUM DRIVE SHAFT
WITH THAT BEING SAID I HAVE STOCK FRONT BRAKE SETUPS.
CAN YOU GUYS RECOMMEND ROTORS, PADS, CALIPERS, TO UPGRADE TO?
THANKS!
THANKS!
i also need suggestions i got stock breaks and they r junk n i think from it sitting so long outside through the winter when i hit breaks my rear drums make a friction rubbing sound.... also parking break wrks except on unlevel ground.
I thought listing the mods would help just to show I have some power under the hood. I'm looking to stay 5 lug
If you want it to stop on a dime look at wilwood. Im running a race setup they make that has 6 piston calipers on the front and 4 piston on the rear. Its also a five lug set up. I love them. I went from stockers that wouldnt stop the car for **** to having to hold the hell on when I hit the brakes.
If you go this route prepare to do some custom line work. I stripped all my stock crap out and ran AN lines everywhere and really cleaned up everything. That not necessary though. You just need a new master and proportioning valve.
Start by upgrading to 5 lug.
Then pick a good name brand and go with a complete kit.
Verify that NO parts were made in China. When a made-in-China rotor or caliper explodes, it will do a LOT of damage, especially at speed.
Well then I got you covered! Lol a lot of people will say go 5 lug for more wheel options, but since I already had nice wheels I stayed 4. If you are looking for stock parts but an upgrade from your system then heres what I did. For the front first things first, you want to locate some gt spindles, this allows you to upgrade to a little bit bigger of rotors. The big picture there is though you can install SVO calipers which are 73mm bore compared to your stock 60 I think it is. I went to oreillys and got performance friction pads when I did the swap, they seem to do a good job stopping.
If you want disc in the rear, you need either a tbird turbo coupe rear end or if you get lucky enough to find one, a 93 cobra rear. The turbo coupe rear is 3/4 wider per side, I have one in my car and I prefer the wider stance. It WILL bolt right in.
If you do that kind of set up you will need to look into master cylinder upgrades, and probably the booster. I haven't done the booster yet cuz everyone says its ridiculous to get in, but suppose to make a big difference.
