Alloy shafts worth it?
hmmm, so the 9" ends eliminate the eliminators ? I guess i'd have to check price differences, I just thought that whole kit for everything minus a gear set and install kit was a decent price. Yea I'll probably have it welded, mines a 110 gas which i've built trailers with that go to the UP many times a year and they hold up fine, i just triple pass everything with it. As for leakage, from my research so far it seems they leak from guys not cutting them properly ? My buddies got a steel chop saw, figure that should cut it better than a grinder although i can usually do pretty good with a cutoff wheel if i make a tape line.
I'll have to think about the arms, if they had the mounts i'd grab them for sure.
yeah leave it to a high power welder also i would not use a cut off use a true saw thats not something you want not straight or off tilt. the 9" ends act as a clip elim that little u bracke holds the bearing in place. i wasnt thinking earlier you may have to change brakes but i am not sure at this point you may need to research that a bit but i know they make drums on 9" kits so it probably wouldnt be an issue. But feel free to stop by after 5 or 6 tuesday -friday ill be taking the car over to a guys house to have the front end and hood looked at for mounting tomorrow so i wont be home in the evening.
hmm, guess ill have to do some more research on what i'm gonna do for the housing ends. On a side note since ill be doing this i will go 5 lug and need some new wheels, didn't you put new wheels on your car this year ? You still have the old ones ?
bradleyb
11-27-2015 07:50 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
