too much hp or how much
07-31-2012, 10:37 PM
is 450 hp too much hp for my 1988 5.0 turbo for my daily driver at 10 psi or can my stock block handle more
07-31-2012, 10:53 PM
Depends how well it's tuned. You're right at the threshold of when they start cracking.
07-31-2012, 11:39 PM
it tunes with a big air sct 3000 maf its a solid tune i just here of guys with 550 hp stock block daily drivers
08-01-2012, 06:33 AM
I agree with mattdel. Some guys run big numbers for years without issue. Some guys break **** as soon as they ad power.
08-01-2012, 06:26 PM
it also depends on things like machine work, balancing job, and assembly! that goes a long way!!
08-01-2012, 10:19 PM
^^^^^^^^^^^^^^^He's correct^^^^^^^^^^^^^^^^
08-02-2012, 12:15 AM
if you're putting a bunch of money into it anyway, buy an aftermarket block and never worry about it again.
08-02-2012, 12:21 AM
i wish i could get a block too much right now my shop said it was a safe tune just asking if guys are doing it with no problem
08-02-2012, 07:31 AM
Quote:
Originally Posted by
thegstring
Easy to say that but money is always one of the biggest factors in modding. If money was no object I'd just get a new GT500 and be done with it.
08-02-2012, 07:46 PM
For something around 500hp a stock block done right will last most of the time! spend the extra money on the studs instead of bolts use a main support where if your block lets go that all you will loose!
