5.0 power
5.0 power
What would you guys think if I said I wanted to put some 170cc in 60cc ex heads with 1.7 rockers on a stroked 302 with high rev manifold switching to a much simpler carb setup- 4 barrel 800 cfm edelbrock? It's off of a 91 Lincoln (5.0 HO stock but getting bigger heads)
Just for a simple powerhouse or is this over doing it? ( for a drag setup)
Any suggestions?
Any suggestions?
That cam is way small. So are the heads. you need some thing in the 190cc range, if not more if you are planning on racing the car.
I don't think I'd use the Edelbrock carb either, 750 mechanical secondary is what I use, built by Quick-fuel on a Edelbrock Vic Jr intake......
Car runs preety good considering that I'm about 3200 altitude and usually get 4800'Air density. 10.85 @ 126+
