15.3 in the 1/4...wtf
So I have an 88 lx, 40,000 on the motor, longtubes, xpipe, flowmaster 10s, 3.73s, short throw shifter
now i know its no race car, but a it is not a 15 second car
all the ignition system has been replaced... my first thought is timing, or the heads are bad. I was racing my buddy with a notchback that runs 13s... through first and second I was right up with him, if not ahead, the second my car hits third it loses all its power. So would timing be the first place you would look?
What was your trap speed and 60ft time? Definitely should be quicker than 15's. If your next to a 13 sec. car the first two gears, then loose by that much, something is wrong. Yes check timing, codes, vacuum leaks,. Does it run ok otherwise?
Heres the info off the slip:
R/T: .348
60':2.187
330:6.389
1/8:9.834
MPH:71.24
1000: 12.8
ET:15.323
MPH:89.40
my other thought is the heads could need replacing...and then my friend said its possible the last owner actually put a truck motor and its not the HO
R/T: .348
60':2.187
330:6.389
1/8:9.834
MPH:71.24
1000: 12.8
ET:15.323
MPH:89.40
You can verify that easily. Check firing order.
On a side note, I highly doubt there is something wrong with the heads. You're a full second under the stock time for these cars in the 80's. It could be the long tubes. You give up mid-range pull for bottom end grunt when you install longtubes on a motor with as little mods as you have.
1979-93 truck V8's (non-HO) and 4.2 L V8: 1-5-4-2-6-3-7-8
1982-93 5.0 L HO V8: 1-3-7-2-6-5-4-8
http://www.fiveohinfo.com/fox/ignition.html#firingorder
What has been done to your buddy's car that it runs 13's?
I would expect 14's from the stuff you listed. You sure it's 40k and not 140k on the motor?
