Plugs, Wires, Distributor, coil and radiator.....
I use a $89 AutoZone radiator that cools mine just fine. It is aluminum with plastic tanks. Unless you are making big power numbers or are running boost, it works fine.
I like this stuff for the tune-up parts http://www.performancedistributors.com/
Stay with the stock units on all of those parts. The stock ignition/cooling systems from Ford are good pieces, and replacing them with aftermarket parts on a stockish motor isn't going to do anything except waste money.
I'll second this! OEM ignition components are pretty darn good!
jwog666
12-27-2021 08:09 PM
Omgitsa88Stang
10-05-2015 07:33 AM
