Wire-to-Fuse Box question
Update:
Ok, so I can't get any power to this thing. Crimped the extension wires on, wire tucked everything, and installed the fuse tap. I tested everything and know for sure I'm getting 12 volts throughout the wiring. I even took everything apart and hooked it up directly to the battery just to get it to power on. Nope, nothing.
I'm at a loss. I figured this was pretty basic wiring
out of curiosity , Im guessing the thing used a ciggerette light plug before right?
Are you sure the unit actually needs the full 12v to run ? some of the cig adaptor plugs have a circuit board and some resistors to bring the power down to 6 volts or 10 maybe even 4.7 v or something like that.
Well, the fuse wouldn't dictate the amperage drawn, so that's not the answer. Although it should be fused when this is all said and done. Those skinny wires tend to break really, really easily once you've stripped them of the large rubber sheathing.. something to look for..
Oh i didnt notice that part. I assumed without reading.
Uhh........ idk. Dawson is correct about the power feed of some pieces though. Cell phones for instance use a 5v feed to charge. If it's over 5v the phone will disregard the charge and not allow it, possibly even warning of the issue if it's a smart phone.
