Cam with heads info
Cam with heads info
im sure there is a sticky or some **** out there already but im having trouble finding it, i am getting the tf tw 170 heads. the one with 2.02 intake valves. I need to know which cams can fit in there without any p-v clearence problems, obviously tf stage 1 will and i believe stage 2, but im not very sure, and any help would be greatly apprecieated. I have stock pistons, along with a intake to match the heads, and a full exhaust system.
I can tell you I ran the Crane "Cobra" cam with my TF TW heads, with 1.7 Crane Cobra roller rockers, for many years without issue. To be sure, yes, you have to turn the engine over with a head (finger tight bolted) on the block, with clay on the piston, to check pv clearance.
my biggest thing is that i am going to have to send my cam back in if i get one to big, now can you explain to me how to check it? I mean do i have to check every cylinder, of much clearence is enough clearence is there a certain clay that wont stick to the cylinders etc.
