A 94-95 Mustang 5.0 mass airflow sensor? AmericanMuscle.com sells them but they sell "performance" ones. Not to mention they're almos asking over 300$ for one. I just need a generic, stock 94-95 mass air sensor.
If you're just looking for a replacement stock MAF, then your best bet is a local parts store or the Ford dealership. You can also check Junk yards or Craigslist for used!
I would recommend getting an aftermarket MAF if you plan on heavily modifying your 5.0, but it's completely up to you!
Let me know if you have any questions or need some assistance!
That 300$ is most-likely for a bigger housing and probably dosent come with the sensor lol idk dont know the part number! If you need the sensor only go to the parts store like stated above if you are wanting a bigger housing then buy aftermarket and get the sensor from the parts store...
Just go to a junkyard and get one out of a 6 cylinder...they are the same as the one in the 5.0. I got one from a local junkyard for 30 dollars and it looked brand new
Exactly. I would also recommend cleaning the sensors before installing, especially if someone beat you to it and took off the air box housing, etc. You don't know how long the car's sat in the lot.
NAPA PART NUMBERS for 94
NEC XTP49508 reman
DEM AF10111 new
listing for 95 has to many veriables listed many part numbers.
