My build thread, for real this time
Old 02-28-2013, 09:16 PM
  #21
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by mustangsneverdie
Yea,I know I know, but I did save some money compared to what I was shelling out before
I didn't say anything Ethan, I have performer rpms with the 1.90/1.60 set up on my 89 vert, they are not a bad head
mjr46 is offline
Old 02-28-2013, 11:37 PM
  #22
tinman
tinman's Avatar
Originally Posted by mjr46
it tells me that your tfs heads were not 210cc intake runners and did not have a 2.05 valve combination......catch my drift??
TFS heads on mine were 205cc intake with 2.02 valve, should make a .20 differance?
I don't think so.
Sure doin good jacking this thread aren't we?
tinman is offline
Old 03-01-2013, 07:49 AM
  #23
bluebeastsrt
bluebeastsrt's Avatar
I called summit and cancelled my order on the heads and found out another friend of mine was stepping up to bigger heads so I bought his for $700
http://www.summitracing.com/parts/edl-60379
Those are good heads. you'll be happy with those. And cant beat the price.
bluebeastsrt is offline
Old 03-01-2013, 10:26 AM
  #24
mjr46
mjr46's Avatar
I don't think so.
I think we both know there are to many variables to argue this point, such as track conditions one day vs another, camshaft taylored to one head vs another, ect ect, so thread jack over, bottom line, use what you like and can afford, if we all built the same combo, it'd be no fun to look at anothers car or see it perform.
mjr46 is offline
Old 03-01-2013, 12:01 PM
  #25
mustangsneverdie
mustangsneverdie's Avatar
What cam would work good with those heads? and do I need to step up injectors before I get it all together?
mustangsneverdie is offline
Old 03-01-2013, 12:08 PM
  #26
mustangsneverdie
Anything has to better than E7's
Old 03-01-2013, 12:23 PM
  #27
bluebeastsrt
MM&FF did a similar build using TFS parts and they used 30 pound injectors. Your 19s are probably enough but why not upgrade while everything is torn apart. Heres a copy of the article if you've never seen it.
http://www.musclemustangfastfords.co...r/viewall.html
Old 03-01-2013, 10:35 PM
  #28
mjr46
mjr46's Avatar
the almighty "b" cam
mjr46 is offline
Old 03-02-2013, 01:25 PM
  #29
mustangsneverdie
haha oh yes the alimghty B cam forgot all about that one
Old 05-05-2013, 01:01 PM
  #30
mustangsneverdie
Hey guys, I got my block back from the machine shop, after getting it cleaned, checked for cracks, new cam bearings and freeze plugs. I also had them prime it for me. While I was up there getting the block, I took my heads up there to get a light shave and a valve job(found the exhaust valves were letting air escape.) They called me Friday morning to tell me that I needed new springs, because the height and spring ratings were all over the place, so now it looks like I'm in the market for new springs as well. I should be building the short block tomorrow after work, and I'll post some pics of it tomorrow or Tuesday.
Quick Reply: My build thread, for real this time
