Is my car cammed? (VIDEO inside)
This is somewhat embarrassing but after my complete intake system was installed my exhaust sounds completely different. I'm not sure if its because there so much air going in now that it makes the exhaust louder, or what?
The car kinda sounds cammed to me, when I purchased the car the guy I bought from never did any mods to it, but he was also the 6TH OWNER, which means in all those other owners mods could have been forgotten from one guy to the other. It could be cammed, because the guy I bought it from couldnt tell his *** from his elbow, he said the car had an h pipe, when it was an X pipe clear as day.
ALSO, one of my friends suggested that after the intake install, the car will run rich, which will make it sound "louder". Idk if thats true or not. Heres the sound clip, is it cammed or not?
http://img138.imageshack.us/img138/9...xlhhaddbjg.mp4
I hate to say it but no that is not from it having an upgraded cam in it.
That is from the different air readings the maf is sending the ecm it may clear up and run normal again once the ecm learns where to keep the timing and airfuel mix .
I assume it didn't lope like that before the intake swap. That loping is because the ecm is using the settings it had before the intake. You may need to clear the ecm out by disconnecting the battery for at least 30 mins . Do the idle relearn and then give it some time to readjust all the settings . The adaptive learning on these cars can take some time to sort things out, it may take 25 miles or 100 miles .
Ya definatly get that cable sorted out . I don't know if you read the other comment I left in the other post you made yet or not , but if the cable is not in line it will be stiff or if the spring is stretched further . Like I said I had to bend my cable bracket to get it back in line cause it was stiff too at first.
Sounds like my car did when I got a big vacuum leak on my intake manifold. I made a pass at the track and pulled back into the staging lanes and my car was all of sudden cammed lol sounded great but ran rich as crap at idle. Also it didn't change how the car ran.
I'd just check behind your work and make sure all vacuum ports are plugged up
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
