need help with 5 speed transmision prob
hi guys new to forum i have a 1995 mustang gt a couple days ago it started whining in the trans and today i was driving it and it all the sudden started rattling and i turned around to go home and before i got home it stopped moving and started staking when i gave it gas. it goes in gear fine it and everything still and shakes in all gears not just one. i think it might be the pilot bearing went out in it need some advice it also shuts off when i let out of the clutch likes its in a bind or something thanks.
sounds like the trans may be locked up....check fluid level and condition of fluid/ drasin it and look for metal in it
Originally Posted by mjr46
(Post 8158575)
if the trans is stuck would i be able to put it in neutral and rev the car? and it goes into gears and stuff what happen is i was driving pulled off on to my road and it just started shaking why it was trying to pull than i came to a stop and the car wouldn't pull at all just shook you to death so i turned the car off and got a friend to pull the car the rest of the way home but the car goes in and out of gear just fine and it has transmission fluid in it i check it when the car started whining and don't seem to have any metal shaving i though maybe a throw out bearing or something like that. could a throw out bearing cause that if its not letting the cars clutch engage all the way. |
depends on what's siezed, you gotta undo the drive shaft and make sure nothing there is binding..ie u-joint and rear spins free, after that your gonna have to pull the tranny and inspect all clutch parts , if all looks good, then tranny inspection time
(Post 8158638)
