Front Blinkers & Hazards DONT work, Back Blinkers and hazards WORK
I have a 1995 Convertible Mustang 5.0 manual. Neither of my front blinkers are working for turn signal or hazard but both work in the rear of the car. My fog lights work, brake lights work, tail lights work. I have HID headlights and one of them is out right now but the other works. Can anyone advise me on how to fix this? Thanks!:icon_beerchug:
check your wires running to the multi function switch
Multi Function Switch
Thank you for the suggestion! That is the actual blinker handle correct and you want me to see if the connection is tight/good? Should I be using a volt meter on it or even at the blinker bulb connections? Is this pretty much the only thing it could be because i could order a new lever if none of this works. I hear there are flasher relays as well but im not sure if one of those were out that it would only cause my fronts blinkers to stop. Thanks
you'll have to get a wiring diagram and test power into switch as well as that coming out of the switch to the lights, or just slap a new part on and cross your fingers :)
Crazy as it may sound,look at your ignition switch too,I dont know for sure,but in my 88' I had a turn signal problem and my ignition switch in my column was super loose.
I’m having the exact same issue. You happened to ever figure it out?
START NEW THREAD
Originally Posted by Julian Whittle
(Post 8659916)
https://www.stangnet.com/mustang-for...t-work.891576/ |
