turn signals
turn signals
i'm having a problem getting my turn signals to work i have checked all the bulbs and installed grounds,changed the turn signal switch (know as muilti- functional switch) the flashers changed, all fuses new...HELPPPPPPPPPPPPP
Just to clarify, do they flash at all, do they light up at all, or they are completely dead when you hit the switch?
I'm just trying to help the more knowledgeable guys here, it helps if you can be as detailed as possible when describing your problems.
If you have a voltmeter, can you check the power going into the turn signal switch with the key on and check the power coming out. Electrical problems are the worst. If you can get a Chilton's and find the wiring diagram, find out where the wire is hot and follow it until it's not getting juice. Sometimes there are "in-line" fuses or connectors. One of those could be bad?
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
