Brake indicator light?
Old 03-09-2014, 12:04 AM
Project 5.GO!
Project 5.GO!'s Avatar
Default Brake indicator light?
For some time, my E-brake indicator light has been light has been going on when I accelerate and off when I brake. Today, I took off the center console cover and examined the switch that controls it. It looks like the light should switch on when the contact is made between the tabs on the switch when the switch is let out (brake handle is up), and switch off when the brake handle depresses the sensor, breaking the circuit.
I messed around with the switch manually depressing it with the car running, and regardless of the position of the switch, the light wont go off, although it probably might go off if I was decelerating. Even when I unplug the switch it stays on.
Any ideas?
Project 5.GO! is offline
Old 03-09-2014, 05:25 AM
primetime5.0
primetime5.0's Avatar
check the brake fluid level
primetime5.0 is offline
Old 03-09-2014, 11:36 AM
Project 5.GO!
Hmm... Maybe I went at this from the wrong direction! LOL
Old 03-09-2014, 12:32 PM
Project 5.GO!
Can we all... uh... kinda forget that this post existed?
Old 03-10-2014, 07:26 AM
88 orangepeel notch
88 orangepeel notch's Avatar
LOL, so it's not just me sometimes.
88 orangepeel notch is offline
Old 03-10-2014, 10:34 PM
primetime5.0
Nope must keep the thread open.. JK
Old 03-11-2014, 11:14 PM
Project 5.GO!
Come on now, if this thread were to stay open too long, this little gem will be my legacy to the forum. Teaching the people the value of doggedly going after the obscure, seemingly impossible cause when the simple one is staring you in the face.
Old 03-12-2014, 07:51 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
now if the level was low.................check the brake pads and make sure they are not getting low and trace all lines to check for leaks.........common place for leaks are rear wheel cylinders......fluid level was low for one of two reasons...1. pads/shoes worn...... 2. Fluid leaks
mjr46 is offline
Jb145700
08-21-2022 06:37 AM
TfcCDR
09-14-2015 12:08 PM
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
Quick Reply: Brake indicator light?
