94 5.0 engine wiring troubles! Help!
Hey everyone Im new here and looking for some advice.
Doing a 5.0 swap in my 94 v6 stang.
I had a 89 fox mustang with a rebuilt 5.0 and t5. So far everything pretty much easy.
Now I just need to hook up the wiring for the motor to get it running.
I been told so many different things and Im just looking for a straight answer.
I know the wiring from the 89 fox wont work. But if I get a engine wire harness (fuel injector,alternator harness) will that work to get this thing running?
Most of the sensors that I seen are the same on the 89 5.0 as the 94 5.0 the only real difference I see is the shape of the upper intake and location of power steering pump and alternator.
I have deleted the EGR,smog pump and A/C.
Any pointers would really help before I throw down the $250 for the 94 wire harness.
Thanks ahead of time.
there are no aftermarket replacement options for the 94-95 engine harness. You will need it, as well as the sub-harness that runs from the front fuse panel, down to the block.
You'll also need the right ECM, and trans harness.
waid302
09-14-2015 11:19 AM
