95 Mustang 5.0 bell housing STARTED issue
Old 07-19-2017, 01:29 PM
rodrigopuebla
rodrigopuebla's Avatar
Default 95 Mustang 5.0 bell housing STARTED issue
Dear All!
I bough few months ago a 1995 Mustang GT V8 5.0 with manual transsmision. The car got damage from the bell housing (it broke). A yunkyards sold me one from a v6 3.8 lts saying is exactly the same part. Aparently it does since fits perfecty on the body of the transmission and the engine. The issue Im facing is the started doest get the flyweell. When I put the tranmission I noticed the spacer plate was a liitle bit diferent so i have to cut a little piece. Here in Mexico is very difficult to find the 5.0 bell housing. So may question is, Do I have to use exactly the T5 5.0 housing? Or if I used the 3.8 housing, I have to buy also the started? Does it will fit?
Thank you very much for your comments.
Regards
Rodrigo
rodrigopuebla is offline
Old 07-19-2017, 03:54 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
http://lmgtfy.com/?q=3.8+5.0+bellhousing+starter
oh and welcome to the forums. the link should have an answer somewhere. We really don't have that trouble here so, no-one may have an answer for you.
TrimDrip is offline
Old 07-20-2017, 09:24 AM
dawson1112
dawson1112's Avatar
Originally Posted by rodrigopuebla
Dear All!
Regards
Rodrigo
I will answer this quickly and honestly..
The 3.8l bell housing is not the same as a 5.0l bell housing,, you need one for an sn95 mustang GT 5.0l
dawson1112 is offline
Old 07-20-2017, 08:25 PM
imp
imp's Avatar
The SN 95 Manual Trans. Bell Housing was made deeper by approx. 3/4 inch from those used in Fox Bodies. Otherwise, a '94 or 95 transmission will fit using the shorter, earlier bell, but the transmission input shaft will not be supported by the crankshaft pilot bearing.
That's a bad thing. imp
imp is offline
Old 07-21-2017, 09:23 AM
64bit
64bit's Avatar
Its funny how easily the answers are found on google, yet people still ask.
Dimensionally, it is the same. The ONLY difference is the starter position. The V6 bellhousing can be used by swapping to a 164 tooth flywheel. They are about $75 on Summit.
This isnt even close to what the OP asked...
64bit is offline
Old 07-21-2017, 03:45 PM
imp
imp's Avatar
EXCUUUSE ME? He asked about using a different bell housing. I told him the difference of earlier 5.0 bellhousings.
Sorry you had a problem with that. Just might be useful to others to know that tiny difference not noticeable can cause serious trouble. imp
imp is offline
