Fuel injectors replacment
Old 01-16-2018, 03:03 PM
imp
imp's Avatar
Originally Posted by Derf00
looks like the same thing any rebuilding company does but, he does flow match them too.
Cost of the work he would perform looks to be equivalent to just buying new ones but, the advantage of being flow matched. Something you can't get from a boxed injector.
Flow-matching sounds like a good idea; now when we get an individual O2 sensor mounted at every exhaust port, it wouldn't matter, each injector timed most efficiently, no two ever alike probably.
Seems like I heard some mfr. was doing that, not sure.
imp is offline
Old 01-16-2018, 08:29 PM
slipperman
slipperman's Avatar
Right.
I've sent injectors for two V8 engines to him. Excellent results.
slipperman is offline
Old 01-17-2018, 12:23 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by slipperman
Right.
Good reference for future needs, thanks!
Derf00 is offline
Old 06-04-2018, 10:25 PM
mdj89
mdj89's Avatar
Oh, does anyone know the original brand name fuel injectors on the 1991 mustang?
mdj89 is offline
Old 06-06-2018, 03:18 PM
dawson1112
dawson1112's Avatar
OEM injectors were ford denso.
dawson1112 is offline
Old 06-08-2018, 07:06 AM
wbrockstar
wbrockstar's Avatar
Rock Auto sells Ford injectors that have been remanufactered by a company called GB Remanufacturing.They're $24.79 each + $10 core for each injector unless you send your injectors in when you order them.
https://www.rockauto.com/en/catalog/...+injector,6224
wbrockstar is offline
Old 06-17-2018, 02:06 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if the car is running fine then run some inj cleaner and call it a day, no need to replace stuff that isn't broke
mjr46 is offline
sbrimer
10-28-2009 09:23 PM
Mach1StanG
02-23-2008 07:59 PM
bsteen81
05-26-2006 01:55 PM
ddeaton66
03-30-2006 11:58 PM
87 hatch
03-18-2005 12:32 AM
Quick Reply: Fuel injectors replacment
